Double roller
Deleting it won't cause any harm. It's only used for detecting misfires and won't affect how the car runs. You can have it programmed out.
OBDII crank hub assembly goes like this:
Pulley + crank hub + CPS reluctor gear + crank gear.
OBDI crank hub looks like this:
Pulley + crank hub + crank gear.
The OBDII crank hub is slightly shorter because it has to fit the CPS reluctor ring while keeping the same overall depth. There are two options...use a 93-95 hub or shim your 96+ hub (I would just use a 93-95 hub).
Been there, done that.
i guess i gotta find a OBDI crank hub to use now
Although deleting the CPS has to be done I kind of miss it. It takes away a lot of the diagnostics of the OBDII. If I had to do it over I probably wouldn't. I'd just go with a good single roller chain.
