'95 LT1 Head Gasket
Here's my '95 Z28 6spd hardtop.
Yeah they should be stock, I'll have to check since I know the previous owner did do something with the heads which led to the gaskets being blown. How will I know if there stock vs aftermarket?
your dad might consider this since he knows a little about engines, and pertaining to the amount of mileage on your car..
when you blow a head gasket generally anti-freeze will get in the oil and the anti-freeze gets to the main bearings and can damage them..
if the previous owner drove the car for a length of time with a blown head gasket chances are you might need main bearings also, plus it might save you time later on..
would suck to fix the head gaskets just to have to go back in within a month and put main bearings in it.. antifreeze will wipe main bearings, seen it more than once.
i think you would be money and time ahead pulling the engine and just doing a budget rebuild now.
just my opinion..
good luck on whatever you guys decide.
Nvm these should work.
http://www.summitracing.com/parts/AR...ize|5.7L%2f350
Now my question is before I put it all back together what heads would have came stock on a '95 Z28? I have a chance to buy a set of heads off of a LT1 Corvette. Casting number is 10207648, now would these be worth it for 100 bucks? There complete minus rockers, could I just use my stock rockers?
