SES light
Car drives the same, perfect idle, runs smoothly but those codes pop there heads up once in a while. Should I get a new MAF?
96-97 f-body cars seem to have a common problem with a splice to the power wire to the MAF. Trace the power wire back into the harnes while you monitor the voltage with the key ON. Wiggle the wire around and see if you can get it to fail. Do the same with the connector plug.
I will trace that wire and play with the connector plug. What is the voltage supposed to be at with the key on just for reference.
