supercharged 355 plan
Old Apr 30, 2010 | 04:39 PM
spikester7878's Avatar
Default supercharged 355 plan
Head/cam package: 1670.00-1975.00
LS7 Lifters: 132.00
Comp Hardened Pushrods: 135.00
Comp 1.6 7/16" Roller Rockers: 324.95
Comp 7/16" Studs: 55.75
Comp Guideplates: 16.25
Fel Pro Head Gaskets: 76.00
ARP Head Bolts: 65.00
Melling Oil Pump: 35.00
Melling Oil Pump Pickup: 10.00
GM Oil Pump Drive: 65.00
GM Timing Chain: 155.00
Fel Pro Intake Gasket Set: 20.00
Fel Pro Timing Cover Gasket Set: 15.00
Fel Pro Oil Pan Gasket: 30.00
Fel Pro Rear Main Seal: 15.00
Fel Pro Water Pump Gaskets: 4.00
Percy's Header Gaskets: 40.00
Throttle Body: 260.00-400.00
FAST 36# Injectors: 325.00
NGK TR6 Spark Plugs: 16.00
Taylor 8.2 MM Spark Plug Wires: 65.00
Rotella 15w40 Oil: 20.00
Oil Filter: 5.00
Coolant: 25.00
Brake Fluid: 10.00
Transmission 1850.00
Stall Converter 500.00-750.00
QTP Electric Cutouts: 375.00
Shop Supplies 25.00
looking for any reccomendations on a throttle body,stall converter or any other 2 cents anyone wants to put in thanks for any input you can give
Old Apr 30, 2010 | 04:52 PM
dangalla's Avatar
bottom end?
now just double it and you will be right about on
taylor plug wires suck *****, buy them and you will be buying wires again, just get the msd wires and "made for you" looms to make your own OVC kit
i used a professional products throttle body and i am pretty happy with it
i would think for a boosted application you would need bigger injectors, and an upgraded fuel system
is this for real or are you wasting our time on a dream
d
Old Apr 30, 2010 | 04:53 PM
86formula's Avatar
am i missing the supercharger?
Old Apr 30, 2010 | 05:12 PM
im building it currently i have the supercharger in my closet currently and thanks for the tip on the wires
Old Apr 30, 2010 | 05:18 PM
Puck's Avatar
Are the parts listed purchased already?
I would spend the extra cash on the select series pumps with the more robust housing, and being supercharged I would get 42lb injectors for more headroom.
31camaro's Avatar
look at Precision Industries or Yank for the converter
Old Apr 30, 2010 | 05:23 PM
i was thinkin about a yank ive heard they are good.
and im workin on buying these right now more of a current parts list
Old Apr 30, 2010 | 05:29 PM
any ideas for a cam or heads. i will be running about 8 lbs so im not looking for a crazy heavy cam
Old Apr 30, 2010 | 05:38 PM
31camaro's Avatar
idk who you are paying almost 1900 to build a transmission but thats way too much, a built 4L60E shouldnt cost more than $1k
Old Apr 30, 2010 | 05:43 PM
any reccomendations on where to but a built 4l60
Old Apr 30, 2010 | 06:08 PM
dangalla's Avatar
maybe for some complete junk that will only last 200 miles, he is about right, do a search though and see who you like - performabuilt or another major company like that is the only ones i would consider though - if you want it to last more than like 500 miles
for heads, look into either elliots portworks(LE) or advanced inductions (AI), call them both and do some searching, you will be happy with either one - and have them spec you a cam to match your entire setup
you are going to need to do some research about your fuel system though, at minimum you will need a racetrronix pump and harness, and you need to calculate your injector size, but i can assure you it will be larger than 36#
i agree with the upgraded oil pump, with a "gm white spring" and make sure you port and blueprint it.
what about the bottom end components and machine work, with a boosted setup some attention to detail here is well deserved
Old Apr 30, 2010 | 06:13 PM
thanks. and thats the next part im workin on now ill prolly have this project done in about 3 years
