LS1 Steering column in LT1??
Old May 1, 2010 | 10:20 AM
4thebirds's Avatar
Default LS1 Steering column in LT1??
Will a 98-02 steering column work in a 93-97, given everything else matches, i.e., manual tranny, etc.?
Old May 1, 2010 | 10:26 AM
1badzee's Avatar
There's a write-up somewhere on here that explains how to do it. Transmission type doesn't matter. You just have to separate the LS1 shaft and re-clock it so it lines up with the LT1 one, then tack weld it together and you're good to go.
Old May 1, 2010 | 01:04 PM
4thebirds's Avatar
Thanks for the info.!
