what injectors?
Old May 18, 2010 | 03:50 PM
1961ba427's Avatar
What are the LS1 injectors rated at? What other LSx injectors will work?
Old May 18, 2010 | 04:53 PM
96capricemgr's Avatar
Most LS1 injectors are 28lbs at 58psi. Once you convert that to LT1 pressures they are slightly SMALLER than stock LT1 injectors.
There were some that were 32lbs at 58psi.
Old May 18, 2010 | 10:13 PM
1961ba427's Avatar
That doesn't sound like a good idea then, unless maybe you were to turn up the FP on the lt1?
