AC FAILED... need help
Im probably going to by a new ac. I have a 1995 lt1. What is the best Ac unit out there??? thanks
1. You orifice tube could be clogged.
2. You may have a leak in the system.
3. The evaporator box drain could be plugged. When this happens and it fills with water, the evaporator becomes an ice ball, and you don't get cold air.
If you do have to get a compressor, NAPA is your friend.
You heart is beating in your chest a week ago. You are perfectly fine. Your blood pressure is normal.
a week later, you die when an artery gets severed when Gregrob stabs you.
Do we assume that because everything is good a week ago, that Gregrob couldn't spill your blood today?
The issue with running it empty depends on where the leak is. You could end up sucking your system full of air/moisture. Moisture in the compressor oil = acid.
out ,before recharge procedure .if not compressor will not kick on . that
type of commpresor on lt1 cars are notorious for leaking i went through 2
used ones before i finally said **** it and bought a new one .
