High idle
Old May 8, 2010 | 10:02 PM
jay97lt1's Avatar
Default High idle
My car idles good when I first start it but after I drive it and come to a stop it idles at about 1800 rpms for a while before it idles down to 850
Old May 8, 2010 | 10:04 PM
RamAir95TA's Avatar
Knowing your list of current mods will help greatly.
Old May 8, 2010 | 10:14 PM
jay97lt1's Avatar
383 11:1 comp ported stock heads and intake XFI 292 cam ported TB morso cai long tubes ory corsa catback M6 Tryed a differant TB with no change.
Old May 9, 2010 | 12:28 AM
Wicked94Z's Avatar
check your iac follower tables, could be fuxxed up, or your iac is bad. vacuum leak?
Old May 9, 2010 | 09:39 AM
jay97lt1's Avatar
I changed to a know good TB off a buddies car with no change I spayed they motor with with WD-40 to see if the idle changed I didnt hear any change Im thinking a leak at the rear of my intake
Old May 9, 2010 | 11:50 AM
fex77k's Avatar
The only time my car ever held 12-1400rpms at idle was from an intake leak. When I start my car it will hold at under 2k and then work its way down to under 1000.
Old May 9, 2010 | 12:08 PM
RamAir95TA's Avatar
Same. My old Z28 had an intake leak (after my father snapped off an intake bolt and decided it would be okay). Since then it had an intermittent high idle.
Old May 9, 2010 | 12:17 PM
Wicked94Z's Avatar
well since it was confirmed you had a shitty tuner, your idle tables could be all fucked up. If you could look at the tune that would rule that out, before you go changing intake gaskets.
Old May 9, 2010 | 01:01 PM
jay97lt1's Avatar
It just started doing it
Old May 9, 2010 | 05:33 PM
fex77k's Avatar
Then it is going to be a vacuum leak.
