383 cam
Old May 10, 2010 | 10:33 AM
domestic disturbance's Avatar
Default 383 cam
well guys I got my motor back apart... I was jw what about the best cam to go with on my setup... It is 383, deck 0, 12 half to 1 comp, le3 heads, I had clearance issues with my old cam so we sent it off to have some grounding on it, and it clears now, Im jw what a good nice size cam to go with ... Im trying to make some serious power oh btw im spraying the car, plan on shooting it with about 250+.... looking for some good routes on cam!
thanks chris
if ya need more info fell free to ask! Btw the setup i have now went 7.54 on motor with a sucky 1.9 60ft leaving off footbrake and lifting before 1/8 mile, I have not left on t brake yet... That was the first pass I have made on the car, I beleive I have some room to play with on cam is why I ask!
Old May 10, 2010 | 10:46 AM
myltwon's Avatar
if you have LE heads I'd recommend getting an LE cam, doesn't cost much more than an off the shelf one
Old May 10, 2010 | 10:49 AM
Well also im thinking switching to solid roller... but dunno
Old May 10, 2010 | 11:31 AM
robsquikz28's Avatar
If your getting a solid roller then go with Lloyds new solid roller. IF you want to stay with hyd. Get Lloyds le3 cam, it will be perfect either way.
Old May 10, 2010 | 02:56 PM
travie319's Avatar
I have a New HR Comp Grind for sale CHEAP if you want to go that route. It would go perfect with your setup if you decide to stay Hyd.
It's an Comp XE Lobe
Specs are:
248/254 @.050
.600/.617 W/ 1.6 RR
Lobe Sep: 110
Old May 10, 2010 | 04:44 PM
thomas89xj's Avatar
i may be intrested in your cam shoot me a pm
Old May 10, 2010 | 05:10 PM
travie319's Avatar
Replied
Old May 10, 2010 | 07:02 PM
slomarao's Avatar
I would go with a custom from LE whether its a HR or SR is up to you.
 Michael S. Palmer
