PITA pacesetter issues
Old May 10, 2010 | 01:42 PM
S_carve's Avatar
Default PITA pacesetter issues
Ok i have a 95 Z28 and Im in the process of putting pacesetter long tubes in it. I bought the headers new from someone that had his car totaled out. The problem is that these are 96-97 ones. They bolted up fine but Iv had major issues with EGR tube being in the way of the trans dipstick tube. I tried bending it as much as possible but its still in the way. Are these any different from 95 to 96?
Also, I already knew the AIR would not bolt up due to different size threads but the passenger side air tube on the header is pointed right at the strut tower and wont allow me to screw it on. Is this different too? What else is different?
Old May 10, 2010 | 02:05 PM
infinitebird's Avatar
the ones with emissions fittings are different, there's one for 94-95 and one for 96-97. the non-emissions ones are the same for all years.
Old May 10, 2010 | 02:47 PM
S_carve's Avatar
I know they are different fittings, but is the shape of the header or location of the sensors different?
Does anyone know the part number for the secondary air valve for a 96?
Everywhere I look its all the same part number for 94-97
Old May 10, 2010 | 03:19 PM
S_carve's Avatar
Ok so 94-95 air tubes are male threads and 96-97 air tubes are female threads. I would need either and adaptor or airtubes from a 96. Thats the difference.
Is the egr hook up still the same spot between years?
Old May 10, 2010 | 03:54 PM
Smoke Em's Avatar
for the egr hitting the tranny dip stick you need to cut it off an weld it so it will fit. heres a pic of mine after i moved it
Old May 10, 2010 | 04:55 PM
S_carve's Avatar
Thanks for the reply and pic. Too bad its all back together and i wont be taking it off any time soon. Is that a common issue with pacesetters?
Old May 10, 2010 | 04:59 PM
red-_-z28's Avatar
why not just cap everything off? thats what i did
Old May 10, 2010 | 05:47 PM
Smoke Em's Avatar
i really havent heard anyone else having egr issues like that. how did you end up fixing it?
Old May 10, 2010 | 07:57 PM
S_carve's Avatar
The car will be on the street and needs to go through emissions, which requires all the emissions hooked up.
I didn't bolt the dipstick in yet. I tried to make a spacer for it but it didnt work. Im looking into a flexable one like Lokar's. Why are we the only two with the same issue?
Now I have issues with the header on the drivers side being too close to the floorpan and the support just behind the end of the header. It wont let me slide the y-pipe on.
Old May 10, 2010 | 08:31 PM
Smoke Em's Avatar
i had that problem too. i heated the header pipe up then used a pipe to bend it down. we may have just gotten a bad batch or something.
when did u order yours?
Old May 10, 2010 | 09:23 PM
S_carve's Avatar
Im not sure when the guy I bought them from ordered them, but they were new.
I think the reason this car has given me more problems than any other car iv owned is that it knows how bad im going to beat it when its done.
Old May 10, 2010 | 09:31 PM
Smoke Em's Avatar
haha it will be worth it when its over
so does your header kinda look like this, going into the floorboard
Old May 11, 2010 | 08:04 AM
S_carve's Avatar
Looks exactly like that! My headers had both the issues as yours WTF. Im wondering if the poly mounts will help.
Anyone else or just the unlucky 2 of us?
Old May 11, 2010 | 10:23 AM
Smoke Em's Avatar
im thinking if you replace the motor mounts and they are both worn, when you replace the drivers side mount it will actually make it worse by picking the header up even more
