96-97 4l60e in a 94 lt1
can i make a 97 4l60e work in a 94 lt1 trans am?
thanks
i have a blown 94 4l60e out of the car that i need to replace the trans. i have a 97 4l60e sitting around that im trying to see if i can make it work in the 94 trans am so i dont have to go and buy another trans. just use the one i got now
http://shbox.com/1/harness_connector_faces.htm click on the 4L60E tab at the bottom of the page
I am pretty sure that the non PWM solenoid is fine, and i think I can still use the early style VSS (just change speed values in the pcm), but im not sure if the shift solenoids are the same or not. I am 99% sure it will work but im still not positive
