Help with an optispark
Old May 23, 2010 | 04:42 PM
l 95 Trans Am l's Avatar
Default Help with an optispark
I'm posting this thread because people stopped replying to my other one and I need input. My LT1 has a problem where it cuts out in the heat, and only cranks for 15-20 mins. My next guess is the optispark. I got a DTC 16 code when i scanned it stating a low resolution pulse from the opti. Also got a DTC22 stating low voltage to the TPS. Which i doubt is the problem, but im going to look into it. I need opinions before I continue throwing useless parts at it.
P.S the previous owner did an opti change in 07', and what did he use besides, the junky, garbage POS-
...Accel
Old May 23, 2010 | 04:49 PM
01ssreda4's Avatar
Try a Chandler Motorsports Opti. $114 shipped and people seem to have good luck with it. Regardless, you're gonna be changing it soon
bigj2717's Avatar
Have you checked the opti harness and the tps connector?
Old May 23, 2010 | 05:01 PM
I was just gonna check it while i do the swap. I refuse to have accel junk in it. And i dont know if I wanna try one of those optis, it will save me money, but idk if I want it blowing up.
Does anyone else own a chandler motorsports opti?
Old May 23, 2010 | 08:00 PM
01ssreda4's Avatar
a couple of people have chimed in in another thread saying theirs is living well.
Old May 24, 2010 | 08:16 PM
Anyone else help me out?
Old May 24, 2010 | 09:52 PM
defaultexistence's Avatar
Throughly check out your engine and opti wiring harnesss'!! take a long *** flat head driver and un clip opti harness from opti ,take a flash light and shine down in opti connection hole and look for arcing,corrosion,ect... check tps,iac,ect... connectors for spltis/shorts where wire pins in to top of male connector plugs
