wiring help?
Old May 30, 2010 | 07:43 PM
SPEED#1's Avatar
Default wiring help?
Down by the starter there are a few wires that go near the starter. 1 of them I need help with? ok is the knock sensor, the big open end is for the starter and the purple wire is to the solenoid. But I have one small black wire with a white tracer. WHere does this go? Does it bolt up to the block as a ground or what? thanks Tech
Old May 30, 2010 | 07:49 PM
1badzee's Avatar
Yep, sounds like the ground for the PCM. I have mine bolted up elsewhere.
Old May 30, 2010 | 07:53 PM
SPEED#1's Avatar
Where can I bolt this up to, its a very small eyelit. WHere does it go, any pics?
Old May 30, 2010 | 08:15 PM
SPEED#1's Avatar
got it thanks
Old May 30, 2010 | 11:29 PM
RamAir95TA's Avatar
I forgot where it bolted to when I did my motor swap, so I drilled and tapped the frame rail.
Old May 31, 2010 | 08:45 AM
shbox's Avatar
Old May 31, 2010 | 09:30 AM
FASTFATBOY's Avatar
There is one in that harness with a very small eyelit that goes to the starter.
My ECM ground goes to a stud on the oil pan rail.
