Grinding Noise
Old May 31, 2010 | 06:47 PM
00FlowCamaro's Avatar
Default Grinding Noise
This just started recently within the past week. Whenever I'm in first gear to get the car going from a stop or whatever and I'll have clutch halfway out to get going it will make a grinding noise and then following that you can smell something like when you weld metal. It doesn't slip nor does it have problems shifting into any other gear.
Anyone have a clue?
Car is a 1996 Z28 with original clutch and everything.
Old May 31, 2010 | 07:45 PM
mark97ta's Avatar
it's the throw out bearing grinding in to the pressure plate... time to replace the clutch... my 96 ws6 done the samething
Old May 31, 2010 | 08:01 PM
All I need to get is a clutch and throwout bearing? Anything else?
