piston and head question
Old Jun 1, 2010 | 01:41 AM
SPRAYED Z's Avatar
Default piston and head question
will this piston and these heads work?
sbc125030f05
LT1 LE3 heads are designed for "built" bottom ends using after market pistons
(Mahle, SRP, etc) with larger valve notch to clear the large 2.055 intake valve.
thanks guys, Tom
Old Jun 1, 2010 | 02:16 AM
JB_97ws6TA's Avatar
depends on what you want to do with the car. those pistons are for a 6 inch rod which I am sure you are aware of and if there are any plans for spray or boost personally I would stick with a shorter rod. they only have 5cc reliefs so depending on head gasket thickness and the LE heads which I believe usually finish up around 58cc you are going to have to balance compression ratio and quench distance depending on how large the camshaft is to help bleed off cylinder pressure so long story short you have not provided enough info for anyone to really give you a good answer
Old Jun 1, 2010 | 02:59 AM
Wicked94Z's Avatar
shouldn't have any issues.
Old Jun 1, 2010 | 03:03 AM
JB_97ws6TA's Avatar
you're right if he is running e85 or leaving the deck height stock and using a .060 thick head gasket...shouldn't run into any problems at all
Old Jun 1, 2010 | 04:32 AM
Wicked94Z's Avatar
maybe he wants to run q16 or something? i think he's asking about PTV, not compression.
Old Jun 1, 2010 | 09:06 AM
Corey @ Clayton Racing's Avatar
we've run those pistons with 2.08 valves no problems, but you should always check the clearance anyway.
Old Jun 1, 2010 | 11:51 AM
jaycenk's Avatar
yup
Old Jun 1, 2010 | 01:14 PM
robsquikz28's Avatar
bp 93 gas and should be good to go, just check for clearance anyway. other than that Many people use that setup.
Old Jun 2, 2010 | 12:25 AM
SPRAYED Z's Avatar
Awesome that was my biggest concern. ALso whats the best method for checking PTVC?
How much playdo do I use?
any vids on this?
Old Jun 2, 2010 | 08:34 PM
Bust out with the playdo
Old Jun 2, 2010 | 08:55 PM
RamAir95TA's Avatar
Tootsie rolls FTW.
Old Jun 2, 2010 | 08:56 PM
Wicked94Z's Avatar
it's pretty straightforward. clay in the valve reliefs. you need to use a solid lifter because the hydraulics will bleed down. turn the motor over. take the head off, slice the clay in half and measure the thinnest part on both the intake and exhaust side. unless you're running a large by huge cam i doubt you'll come close. Shoot for about .100 on the exhaust, you can run the intake tighter, maybe .080. Think about valve events here... as the piston is coming up it's chasing the exhaust valve, but the intake valve is coming down towards the rising piston. If you're running tight on either side you can retard or advance the cam to get you some more clearance.
Old Jun 2, 2010 | 09:05 PM
Yea if you dont understand what they are telling you, im sure this is a vid on youtube,lol
Old Jun 3, 2010 | 09:42 AM
I know it a ford.......but there are a few good pictures of claying the valve reliefs toward the end of the album. You can see how we slice it with an exacto knife to check various areas.
http://s553.photobucket.com/albums/j...20Dart%20Ford/
Old Jun 3, 2010 | 10:41 AM
SPRAYED Z's Avatar
got it thanks guys
Old Jun 3, 2010 | 01:35 PM
AChotrod's Avatar
your not supposed to use playdoh you use modeling clay for best results and easier clean up.
Old Jun 3, 2010 | 01:40 PM
WS Sick's Avatar
you r cam will facotr into this alot, but as said check it anyway.
