coil per cylinder?
Aside from a bit of basic splicing work around the stock coil location, the LTCC system is plug and play but you will need to fab some way to hold the coils.
Like others, if I was doing this today, I’d move to the EFX Connection LS1 PCM system in a heartbeat.
The MSD LS1 replacement coils have had a poor track record, many have posted problems with them and no better performance over stock.
I also had the MSD distributer and it also worked well, I was happy with it’s performance. However, some have posted issues with them which I think only affected their early shipments of them.
I think Deltec is no more.
I still have a Deltec blank cap if anybody’s interested.
A Last edited by wayneg1035; Jun 3, 2010 at 08:29 PM. Reason: Added SIG
Without the screws, the wheel will stay in place but flop around loosly.
Awith the EFi system you will also be able to use the lsx tuning software so you will be able to find someone to custom tune it easier than trying to locate a lt1 custom tuner.
I then upgraded to LS2 coils. Still ran good, no coil issues.
I then upgraded to LS2 truck coils with the heat sinks on the back after seeing what they do on Megasquirt. WOWZERS, did that ever make a difference! The engine was a whole different (much bigger) animal! HOWEVER, the engine pinged at lower speeds pretty badly. I started looking into changing the dwell and timing curves in the PCM and took them out and shelved the coils until I had a programming fix. It was around that time I starting having valve spring issues and a loose valve bouncing around in it’s cylinder so the car got parted out which led me down the LS1 car path.
Second question: I noticed LS1 coils are more expensive on eBay that other "LS" coils. Do I have to use specific LS1 coils, or will other GM "LS" type coils work just as well?
The good thing about this system is that the high voltage is taken out of the opti-spark distributor.
LS1 and LS6 coils have a specific plug & pin arrangement. All other coils (LS2, 3, 4, 7, LQ4, LQ9, etc...) have a different plug & pinout.
I believe you can request the LTCC kit with LS2 style coil plugs.
Sorry for the threadjack!
Hil
You’ll need to use any coil except the truck coils with the heat sinks.
