LSx or stay with the LT1
but, hey look into a budget build for your motor.. save the money you would have from a conversion..
That's pretty damned good bang for the buck, no matter what car ya own.
LT1 FTW
It's really all in what you want to do, I did the swap because I bent #5 connecting rod on the stock bottom end into a S shape NA and I felt it was time to try something new. I didn't buy a ls car to start because I had a decent amount of money in the chassis and suspension that I didn't want to do over. For my model year all that really needed to be converted over was the wiring harness & Fuel system everything else swapped right in.
The Options are almost endless with the LS stuff and you can have any cubic inch you desire and afford. But as said the ultimate decision is up to you have how much you want to spend. Just like with building a engine the little things will nickle and dime you! And in the end it will all add up to more then you expected.
great advice.
Im going to stick with the LT1 after a little furthur research and calling a few shops. Goin witha forged eagle crank and h-beam rods along with some forged mahle flat tops. Lower end components will cost me just shy of $1500. Short block labor is $1325 (clearence, file fit rings, deck, assemble, degree cam, and splayed including the caps...anything that needs to be done to fully assemble a 4 bolt splayed shortblock) and $975 to fully port and polish my Trickflow 195cc heads, mill them and port match an intake.
$$ total so far:
Fully ported Trickflow 195cc heads w/ labor and port matched intake - $1775
Custom cam - $300
Assembled short block w/ labor: $2825
Double roller timing chain - $50
Gaskets - $150?
Total: $5100 not too bad for an LT1 longblock easily capable of 500 rwhp
$$ total so far:
Custom cam - $300
Gaskets - $150?
and $50 for an LT1 timing set? please, hook me up on that. no seriously.
oh if you go to summit you can get a re-ring kit complete with bearings, gaskets and (of course) rings for $330.
and another thing, 8 rods, 8pistons and a crank is all the LT1 shares with the traditional chevy small block, and even then it is 1 peice main stuff.
again, not being a dick here, but i will travel from bristol to, where ever, for that kind of price on machine work.
Im not saying that people shouldnt build high HP engines but with an LT1 you need careful planning, TLC, and know what to look for. LSx is just HP in a box, open it up and there it is.
The shop is Burlington Performance
9600 East 59th Street, Raytown, MO - (816) 353-8417
Summit brand $37.95 http://www.summitracing.com/parts/SUM-G6601/ Any SBC roller cam double timing set will work if you're using an EWP
Whats your point?
You can use any hydraulic roller cam, timing sets, and oil pans as well
on cams, i may be wrong, but you can't use early stuff on the LT1 unless you go without the opti (you need a way to drive the opti).you can use LT1 cams in earlier blocks though.
oil pan? gotta use one piece and go without the oil level sender if you use the early stuff.
valve train? got me there. i heard you can also use LS7 roller lifters. arn't they factory replacement for LT1?
the point about summit was just to let you all know its a pretty good kit.
and to slowmarao, you've got a point. but i guess you could use a rotary dial phone to call grandma on sunday instead of your trusty iphone but would you? i've spent 10 years building pontiac motors to keep up with big block chevys and i am tired of working so hard to make horsepower. i want my horsepower to be like my women, easy AND cheap.
Change the pin in the end of the cam
That is very correct, but it still works...Anything 1pc rear main works on LT1
The LS7 lifters work great they are about $130 nowadays but the Caddy lifters are the best and I think they are in the $200+ range
The other was a friends ls2 with prc 215 heads, ms4, etc that only did 417 through an m6.
It's not as easy as you think to just slap a 500 RWHP ls combo together as most would lead you to believe.
