cam bearing
Old Jun 4, 2010 | 08:04 PM
pillarpod's Avatar
Default cam bearing
wanting to do a cam swap this july, any one know where i can pick up the tool for the cam bearing and how much it roughy is. thanks
Old Jun 4, 2010 | 08:30 PM
Badazz 97 TA's Avatar
you cant install cam bearings with the motor still in the car. Atleast i know one of them you cant.
Old Jun 5, 2010 | 12:41 PM
RamAir95TA's Avatar
Definitely unwise to try and change the cam bearings with the motor still in the car.
Old Jun 5, 2010 | 02:45 PM
SS RRR's Avatar
Village Troll
Cam bearing as in singular?
Old Jun 5, 2010 | 03:05 PM
pillarpod's Avatar
swap out my Opti for MSD, after the swap noticed i have a slight oil leake now, did some searches on here, sounded like that was the cause, and was planning on replacing it when i swapped cams. Or do i have this all wrong?
Old Jun 5, 2010 | 03:30 PM
shbox's Avatar
Perhaps you are referring to the opti seal in the timing cover? Cam bearings don't cause oil leaks.
