Opti replacement
i used RTV for the new water pump installation, and assembly lube on the Opti cam shaft, i put the two black rubber rings in hot water for a few minutes to loosen them up and make sure to align the notch correctly(A) with the cam shaft pin(C). i did a few test fits prior to final installation...
