lifter question? roller rocker adjustment?
Now do I have to start up the car and let it run to pump up the lifters AGAIN or not?
THe lifters were last used in october last year. So is the valve lash good to go or not?
thanks guys
Easier, yes.....and quite a bit messier!
One thing to consider, especially if you're trying to set up the preload at some small increment like 1/8 turn, as the CompCams 875Rs require. Initially get the preload close, then let the engine fully warm up, then re-do them. With the aluminum heads and iron block, things warm up and expand at different rates, and it takes a while for everything to fully expand. Also, if you do a lot of your "mods" in the winter, while the car is off the road, as many of us "northerners" do, with the car quite cold, everything has "shrunken".
I had the 875Rs in my car for a while, and it was tricky getting them adjusted properly. It took several attempts before I was able to get them right, and as amazing as it sounds, having the engine fully warmed up (as well as being patient) was one of the keys in their proper adjustment. I don't drive the car in the winter, however I'll start the car and let it warm up 2-3 times during the off-season. I don't like leaving tension on half the valve springs for that long. Anyway, the 875s, even when propely adjusted, would be quite loud until the car warmed up....
if your questioning yourself take the 30 min it takes and redo them since the covers are already off, but the odds are they will be ok
You'll find that the IC/EO method is the procedure now recommended in the magazines, cam company catalogs and engine build up articles. More than 40 years ago the adjust while idling method' was the recommended method but no longer. Of course, some things die hard.
Times change and so do recommended procedures once a better method is found. In fact, I regularly set mine with the engine on the engine stand, bolt on the valve covers and install the engine, never having to touch the lifter preload again.
Jake
Some methods are clearly "better" than others even though any of them may give the same result. I could prepare and post here a listing of the different ways to properly adjust lifter preload, or degree-in a camshaft or the amount of preload that should be used. Industry R&D, feed-back from reputable engine builders, magazine editors, camshaft companies most often either specifically identify which method is better or by their continued use of a specific method indicate so.
Take as a recent example the dyno results of seven different camshafts in the same engine featured in Engine Masters. The results, in a couple of cases, fly in the face of what so many post here and on other Forums; that longer duration cams are needed to reach "X" amount of power. A guy running a HotCam is often told he needs more (longer duration) cam to reach his power goal, yet the dyno tells a different story.
Forum members can substitute another word for the word "better" should they choose, but hopefully they won't get lost in the meaning being conveyed.
No need to continue an extended back and forth on this. Suffice to say I always try to pass along the most often recommended, and yes, better way. In addition, I try to remain prepared to support my posts by having my sources available to cite rather than making unsupported claims.
Jake
someone at comp cams looks at it and goes ahh this isnt a good idea to recommend to customers to stick there hands near a running engine and have oil leak down on to hot manifolds in a garage while unlike but could catch fire.
on the other hand you adjust them on a non running engine and not much can happen.
