Need help
Old Jun 10, 2010 | 07:27 PM
95ZR28's Avatar
Default Need help
I am new to my Lt1 camaro. I need help figuring out how to fix my short... My horn and my cig dont work. The fuse under the hood is good. The one inside the door is bad! I change it and last for 3 sec pop! Put 5 more in and they just pop as soon as the prongs touch. Where do I begin to fix this and how? Any suggestions would help...
Old Jun 10, 2010 | 07:31 PM
pro94lt's Avatar
First do you have anything spliced into your cig lighter? any added electrical items? If you don't I'd start with tracing the cig wire back to the fuse box shbx should have the schematic on his site. Check that out it and the horn are probly on the same fuse. If you don't find anything their go to the horn.
Old Jun 10, 2010 | 07:44 PM
95ZR28's Avatar
Ok thanks, Ill give that a try!
