lt1 questions please help me!
i replaced the water pump about 5k miles ago
car has orig. opti spark plugs and wires were changed 40k miles ago by the previous owner's friend of a friend (who knows if he changed all of them)
just did an oil change and have NO metal floating in the oil not even shavings
problem #1....................
car has a bad miss, every gear after 4600 rpm car acts like its hitting the rev limmiter
problem #2..................
im getting an annoying (knock, kind of noise- like a bearing or something) its external like its on the outside of motor... in the front.
we used a mechanic's stethoscope and a 3 foot wood pole to press up against the oil pan, top of motor, both valve covers,
its real, real, real, loud and bad right around the water pump
my question is... what does the water pump attach too called? does it attach right to the cam? are there bearings that can go bad in the pump? if i get an electric pump can i delete that shaft (if it is possible)
my next question is as far as the opti goes, is there any type of gear in them? that mybe goes bad? maybe thats causing the miss and also that noise?
thank you for taking the time to read all this, just want to get a good idea how this stuff works before i get into all this....
i used a pair of pliers and started wiggling that shaft that comes out of the motor (for the water pump) and it doesnt go in or out, it just wiggles around a little bit like its loose. seal still looks good though.
so is that shaft even suppose to wiggle like that?
and if not, i can pull the opti off, and crank hub off, since the water pumps off, how hard is it to remove that (timing chain cover?) i dont know whats back there?
also how far does the front of the oil pan have to come down? and what is the correct way to do this???
and if i just remove it all together (since its going to be off) i have a welder for the hole, i may just put an electric water pump on to delete that shaft?
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Have you figured this out yet? i have the same problem after my cam and head swap!
