Anyone running the Comp 236/242?
Typically something with that duration works well in a combo with more cubes because the amount of rpm's it will want with ported heads will be pretty close to maxxing out the stock computer on a 350 and not to mention will be a little sluggish around town (unless you have enough gear, stall, great tune yada yada). Now, assuming you have ARP rod bolts etc. then you shouldn't have any issue with the stock bottom end grenading when you rev it to where it wants to be. It's not a cam I would personally want to run in a 350 but I'm not saying that it won't work or have a nasty top-end. I would spring for that cc503 that's available BUT that is just my .02...
EDIT: I just read you sig and noticed you have a 353, I was assuming you had a completely stock bottom end...Anyways like I said above I assume you have some ARP rod bolts in there?
I know you ran that cam in the past. I have all the supporting mods (1.6 pro mag rockers, patriot springs, SS3600, 3.73s). How did you like that cam when you ran it?
I liked it alot because I was able to have a cam that drove very well around town yet performed very well at the track, at the time I use to DD the car an hour each way to school. I was after a decent street/strip cam that would have some thump to it and wouldn't need to be revved ridiculously high. I actually ran it with 3.73's and a SS3600, perfect combo IMO. I wish I could go back to that stall sometimes, excellent street/strip stall. Everybody wants different things out of their cars but that combo worked well for what I wanted and for someone who wants something similar I think it would be a wise choice.
Just because "bigger is better" is the oldest and most enduring hotrodding mistake doesn't mean you have to keep it going.
I would put a 503cam in a 350/355 before that other grind or a 847.
