cc305 and smog????
Old Jun 14, 2010 | 07:07 PM
1toofastlt1's Avatar
Default cc305 and smog????
hey I live in CA so i have to deal with that smog BS. im building a 383 lt1 forged with a supercharger and I need a cam to help the car breath. will the cc305 with 1.7rr still pass smog?? they will be will stock ported heads.
Old Jun 14, 2010 | 07:20 PM
LTXBOI's Avatar
im running the same cam with 1.6's supercharged... if your close to la area don't worry about smog test p.m me
Old Jun 14, 2010 | 07:23 PM
dang im in sac but it might be worth the drive if i want to go all out. will your car pass smog?
Old Jun 15, 2010 | 12:20 AM
SS MPSTR's Avatar
My car passed smog legally with the CC305. No worries at all.
Old Jun 15, 2010 | 06:56 AM
DAVE00's Avatar
I ran the CC305 in my 383 for 10+ years and passed the sniffer test here in Texas every year with flying colors. Switched it up last year to a custom grind and I'm still out of inspection -
It's a good cam and made to pass emissions. You should be fine.
Old Jun 15, 2010 | 03:28 PM
ok good. i just wasn't sure with the 1.7rr because that would put the lift at .578
Old Jun 15, 2010 | 03:30 PM
DAVE00's Avatar
Not sure about the 1.7's. What spring r u running and are you sure it will handle that much lift? Don't think the lift will affect the emission status of the cam as that will come with the duration and lsa.
Old Jun 15, 2010 | 07:04 PM
Spartan7's Avatar
I barely passed CA smog with a 222/230 112 LSA cam.
Old Jun 15, 2010 | 07:52 PM
im running the pac 1218 good for .600 lift. the cc305 comes in two lsa a 112 and 114 I think I will get the 114 because it will have a smoother idel(sleeper), better low end and I think it will help it pass smog.
Old Jun 15, 2010 | 10:34 PM
Sof86's Avatar
You should be able to pass emissions, but I don't know how strict CA emission standards are...not sure how forced induction will affect emissions either, maybe someone else can answer that.
My 385 with a CC305 passes with ease...and this is with a ported LT4 intake, ported Canfield heads, 1.6RR's, long tube headers, highflow cats, etc etc.
Old Jun 16, 2010 | 06:41 AM
DAVE00's Avatar
You're going to be pushing it with 1.7's IMO. What is your installed height?
BTW - Why are you going with 1.7's as you really won't see that if any over the 1.6's esp with the lift on that cam?
Old Jun 16, 2010 | 01:41 PM
well the way I see it is the more lift the better. 510 /1.5=340 340x1.6= 544 340x 1.7= 578 if my math is right. wouldn't that make more power?
Old Jun 16, 2010 | 02:15 PM
djjab57's Avatar
Who is doing your heads? I only ask cause when i had mine done by LE I told Lloyd up front I was going to stay emissions legal and he looked at my whole build and told me the biggest cam to go with and still pass. I dont know the math or everything to take into account but your head guy may
Old Jun 16, 2010 | 02:29 PM
DAVE00's Avatar
Talk to Lloyd Elliot as he would be the best reference, but I don't think the 1.7's are going to yeild you that much. How is your PTV clearance?
Old Jun 16, 2010 | 05:15 PM
NightTrain66's Avatar
LS1TECH Sponsor
no prob with the 1.7's amnd CC 305 cam passing emissions.
It will barely effect the overlap at all and should easily pass. If it doesn't pass, you have something else wronga nd the cam is not the culprit.
Lloyd
Old Jun 16, 2010 | 06:12 PM
Lloyd
awesome. thanks man
