Rear ABS delete
Old Jun 19, 2010 | 06:43 PM
afterburner82's Avatar
Default Rear ABS delete
Does anyone know if someone makes a module/connector to remove the rear ABS? I did not have my Moser drilled for the ABS sensor and just want to get rid of the ABS light. Can't program it out of the PCM. Can I plug my old one in and just zip tie it up?
Old Jun 19, 2010 | 08:46 PM
RamAir95TA's Avatar
Just remove the ABS bulb from the dash. If you plug your old one in and it's not reading the reluctor wheel it's still going to set the light.
