hard start
Old Jun 20, 2010 | 10:21 PM
dirtynorth's Avatar
Default hard start
My car has always started first try out of nowhere it takes around 3 cranks to start it. Any ideas? Btw its got a good opti fuel filter o2 sensors and the plugs look normal
Old Jun 20, 2010 | 11:37 PM
killagt's Avatar
Fuel pump is first thing I do check ! any code ?
answer these 2 question
1 : Doest your car hard to start after it been park a long time, like over night ? it take 2-3 try before it start ?
2 : Doest your car start up easy after it just been shut off and start again ?
Old Jun 21, 2010 | 12:13 AM
dirtynorth's Avatar
it takes about 2-3 long cranks to start it no matter what no matter how long its been since its last been run. No codes.
Old Jun 21, 2010 | 01:12 AM
dirtynorth's Avatar
i should also add that it almost starts when you first turn the key but it takes another long crank or two to fire.
Old Jun 21, 2010 | 09:28 PM
dirtynorth's Avatar
It also doesn't seem to be running quite right anybody hbave any ideas
Old Jun 22, 2010 | 02:24 AM
killagt's Avatar
I would bet on fuel pump. any info on fuel pump, its still stock or after market ?
Old Jun 24, 2010 | 12:30 PM
MuscleCarNut711's Avatar
Had a very similar issue 2 months ago. It was the fuel pump check valve, replaced the pump and now it's fine.
Old Jul 2, 2010 | 04:27 PM
dirtynorth's Avatar
ok well talking to you guys about the symptoms and talking to some other people i know lead me to believe that the stocker fuel pump is going after 105k. So i ordered a walbro 255 lph stock location pump tearing into that today. Anybody know any tricks on pulling the tank?
Old Jul 2, 2010 | 08:48 PM
Dadic 78's Avatar
mine did the same thing when the fuel pump was on it's way out. it would start, but took a while. your Walbro will solve the problem.
