crank balancer shaking!!!
anyway, for the balancer i would say remove the bolts and hammer it in with a mallet and then tighten the bolts, run the engine and see if it wobbles while rotating
^ Only ill advised, you're sure being nice. Even a plastic dead blow hammer is not a good idea. You can by hammering on the Balancer separate the outer and inner rings by tearing the isolation material on a 13 year old+, multi thousand mile, and already wobbling, cast critical component. If it comes apart, it can do significant damage to the engine and accessories, especially if the car has had dry rot problems in the past, it may need further inspection.
? Has the motor been apart or the timing cover been off recently?
Has the opti been changed recently? If so and an install tool was not used on the hub, the crank threads could be stripped, as the bolt is not long enough to engage the threads properly to tighten back on if used alone.
If no to above
1. Inspect the balancer, check for dry rot and make sure its not coming apart with the two pieces uneven. If so replace the part.
2. Inspect check hub flange and see if it has appeared to have moved forward, check center bolt for tightness, while preventing crank from spinning, crank bolt should be torqued 75 FT LBS.
3. check the 3 bolts holding it to the hub for tightness 60 FT LBS.
Only use an install tool or like means of reinstalling it...Some Autozones have one you can use for free, just leave a returnable deposit, and bring it back in working order the way it left.
With your other problems, that can happen to any vehicle after awhile.
Unless you're the original owner, you have no idea how the car has been maintained, used or abused, and subjected to what type of conditions.
It could have been left out in extreme weather, flooded and used as a Dukes Of Hazzards chase car, for all you know, and they don't show up on a Carfax if not reported.
Good luck
Dub
When In Doubt Do Without
Last edited by 1993 z28 f1; Jun 23, 2010 at 07:18 PM. Reason: spacing, torque specs
the OPs question was: (Do I have to tighten the bolts on the hub or do I have to replace it?)
so since hes talking bout more than one bolt i guess he was refering to the damper pully not the hub !!!!!! i could be wrong
Possibility 1... the outer pulley has come loose from the center hub. Check the 3 bolts that hold the pulley to the hub. (the 3 bolts will easily seat the pulley, a hammer is NOT necessary)
Possibility 2... the bolt that goes through the center of the hub has come loose. This allowed the entire pulley/hub assembly to wobble, and if this happened, the snout of the crank has been chewed, which is serious. However, before assuming the worst, check the bolt that is recessed in the center of the hub. Make sure it is tight.
If not, leave the hammer in the tool box, get a bolt that is about 1/2-3/4" longer, as well as a few flat washers. Use the longer bolt and stack of flat washers to draw the hub back on, then install a new bolt of the original length, along with one flat washer and lock washer.
After looking at this again, there is actually a third possibility, and "mark97ta"s post got me thinking....possibly the elastometric band between the outer and inner rings of the pulley is giving up, and the outer ring is shaking around. If so, time for a replacement....
Once you get a new pulley, it's 3 bolts off, old pulley off, slide new pulley on, tighten 3 bolts in place. Re-install serpentine belt, test drive as necessary.
NOTE: the bolt pattern for the 3 bolts is "asymmetrical", in other words the bolt holes are not evenly spaced, on purpose. Line up all 3 bolt holes before installing bolts.
Same thing that just happened to me from what I saw. The actual center of the pulley is worn out.
And to sum it all up the belt slipped off therefore mangling it. So now I have to buy a new serp. belt. Oh well it was that time anyway.
