Tuning for cold-startup conditions only
Old Jun 23, 2010 | 08:52 AM
wrd1972's Avatar
Default Tuning for cold-startup conditions only
I think my engine needs a little tuning up for cold startup conditions only. It seems to be rich especially if the AC is on because I can smell gas and it sounds rough for a minute or two.
The engine is well tuned and running well once it is warmed up. I get 128/128 BLMs 90% of the time across all cells with never more that 2 points +/- or so. No issues there.
Regarding the injector pulses at idle, I get:
cold idle 1.3
cold idle AC on 1.5
hot idle 1.0
Can someone recommend some things to try to lean out my cold start conditions?
Old Jun 23, 2010 | 09:30 AM
Wicked94Z's Avatar
wideband, datalog, tune, repeat. cold starting and driveability tuning is hard to do over the internet. i probably wouldn't be much help, since the coldest it gets here is 40 degrees
