Interesting problem, please help.
Old Jun 24, 2010 | 06:23 PM
Slowmo_Bird94's Avatar
Default Interesting problem, please help.
My 1994 Formula is randomly cutting out and backfires once before returning to normal. My guess it that the Opti is going. I have wiggled wires with no results. Tell me what you guys think.
Old Jun 25, 2010 | 05:33 AM
Come on guys and gals, I know you have ideas here. The problem is getting worse and I am afraid I am going to get stranded.
Old Jun 25, 2010 | 07:03 PM
brettmc's Avatar
you can try replacing the icm and coil.
Old Jun 25, 2010 | 07:06 PM
mrchyzy16's Avatar
could it be a lose spark plug?
Old Jun 25, 2010 | 07:58 PM
defaultexistence's Avatar
dude you said it yourself,......lets see ...what makes an engine start to backfire and quit running.....IGNITION check not wiggle engine harness, check your opti wiring harness,grounds, plug wires, coil, plugs opti vent lines ,have you changed optis? have you recently tuned it up? how many miles? ect ect ect ect
Old Jun 26, 2010 | 06:37 AM
I replaced the Opti less than 10K miles ago, along with plugs and wires. I have checked all my harness connectors and grounds to make sure they are in place properly.
It feels like someone reaches over and turns off my key, then turns it right back on. It also has to crank a bit to start sometimes.
Old Jun 26, 2010 | 09:02 AM
old93camaro's Avatar
Well sounds like you need to check your coil next then the icm
Old Jun 26, 2010 | 09:25 AM
Actually, I now remember replacing the coil when I did my Opti as it was an original coil. The tip to the coil wire was badly corroded. The car also had original shocks at 175,000 miles.
I know a guy that will scan the car for me. Onward to the next step.
