am I going to need a fuel pump
Old Jun 26, 2010 | 02:34 AM
jay7199's Avatar
Default am I going to need a fuel pump
sorry this is kind of a lame question but I can't seem to answer it for myself.
Im wondering if im going to need a fuel pump when my cars back together.
I know my cars going to be flowing alot more air but I don't know when it becomes a problem for a stockish lt1 fuel system.
So heres the basics of whats going in my car.
355
trick flow 21 degree heads unported
226/360 .565/.565 111
ported lt1 intake
52mm tb
Aeromotive Fuel pressure regulator.
Gona spin it to about 6500 depends where the powers at after i get it on the dyno.
Should be all the relevant info, I still have stock injectors aswell.. I figure if need be some red tops will be fine.
Old Jun 26, 2010 | 02:56 AM
gregrob's Avatar
Depends completely on how healthy it is... with the age of these cars I would do it regardless
Old Jun 26, 2010 | 03:00 AM
jay7199's Avatar
Eh the person who i got it from said he put a new fuel pump in.. but it was probably a autozone one.
Old Jun 26, 2010 | 05:39 PM
spudnick3119's Avatar
Did they cut the access hole in the car? If so, I'd replace the pump for piece of mind. It won't take long.
Btw, you'll probably need injectors like you said. I'm seeing almost 110% DC from my stock injectors at 6300 rpm with just a cam. I'll be looking for some 30lb ones as well.
Old Jun 26, 2010 | 10:08 PM
DAVE00's Avatar
As long as the stocker is pushing good pressure you should be fine. I am pushing 400+ at the wheels with my stock pump. True I only have 45K on the motor but it feeds my SVO 30#ers just fine and pressure stayes constant.
Old Jun 26, 2010 | 10:47 PM
jay7199's Avatar
yeah.. im gona need SVO 30#s im sure. How are these aeromotive FPR? I heard ups and downs about them. I got it for free so I figured might aswell use it.
