crank sprocket removal
Old Jun 27, 2010 | 06:01 PM
jasonz28camaro's Avatar
Default crank sprocket removal
anyone know how to take off the crank sprocket. i just dont know how to get the key out???/
Old Jun 27, 2010 | 06:05 PM
orange94z28's Avatar
I take it your talking about the sprocket for the timing chain. Ive always use a 3 jaw puller just have to be carefull not to mess the threads up in the crank.
Old Jun 27, 2010 | 06:16 PM
so are you saying that the key does nothing and the sprocket can just be pulled off?
Old Jun 27, 2010 | 06:27 PM
aboatguy's Avatar
Yes, you can just pull it off...
Key keeps sprocket from rotating on the crank....damper and damper bolt keep it from moving forward on the crank when engine is running...
Old Jun 27, 2010 | 06:45 PM
Yes just like aboatguy said.
Old Jun 27, 2010 | 07:02 PM
ok i got it thanks... i thought it being a lock it might need to come out first but i see how it works now.
