Using 18* (or 15*) SBC heads on a LT1
Do regular SBC/LTx headers still match up??
Can you still use regular HR lifter and roller rocker arms(in other words a conventional SBC valvetrain)??
Do you think flow number that these heads produce N/A makes the conversion worth it for high performance street???
I am thinking of going this route for my 383 LTx stroker build on my '95 Caprice instead of the usual 23 degree head Advanced Induction or Lloyd Elliot route that everyone seems to go.
One reason in prompting me in going this way is from an article in the February, 2009 online issue of Hot Rod magazine, Lingenfelter Performance Engineering built a 420ci small-block engine with a Bow-Tie block, a Callies 3.875-inch stroker crank, Oliver rods, and a Comp Cams roller. With 11.0:1 compression, 18-degree Chevy heads, and a Bow-Tie single-plane intake manifold fitted with EFI, this big-inch Mouse produced a stout 623 horsepower at just 6300 rpm.
Pistons
Headers(full custom set)
Intake
Offset lifters
Rockers.
Its not worth it IMO. Too expensive for what you get to DO IT RIGHT.
Look up a guy on here N20DAVE, he did this already. Made 700 hp all motor.
With a 12to1 compression 396 and a good set of 23* heads, single plane you can make 600+
Honestly 5-10k probably wont be enough cash though. Dont forget you will need a lot of supporting mods to make a combo that aggressive work, and you cant skimp on parts if you want it reliable.
Yeah you are right about not skimping on the support mods.
I used to believe that too, but then I got a clue, and the car got faster.
