94 lt1 short block build
build will be a high rpm 350 with forged pistons and rods and stock crank with a 242 242 572 572 112 cam with 1.5 rocker arms. heads will be stock castings porting is to be determined.
my question is
i found these pistons
http://www.summitracing.com/parts/TR...art=TRW-L2304F
on some scat 4340 5.7 inch forged rods for 150 and I thinking about getting them.
now using the specs from this site
http://www.camaroz28.com/forums/arch...p/t-52671.html
for stock head specs and deck clearance
and this compression calculator
http://www.kb-silvolite.com/calc.php?action=comp
I have come up with these pistons giving me a static compression ratio of about 12.1:1
are these calculations correct and is 12:1 compression too high for pump gas and thats with 54 cc cylinder heads every site i have found has an argument on the cc either 58 or 54 cc
i know that dynamic compression ratio is equally important and and i will update this thread with that as soon as i can find my cam car
the car is a 94 lt1 ta with a 3200 rpm stall built trans with a shift kit and 4.10 rear end gears. it will have long tubes and ported heads as well
my question is
To have chosen a cam already without knowing what kind of headwork you have goes against all ideology for what it takes to build a well-thought out purpose-built motor. IMO, it's WAY too big for a 350, ported heads or not. And why a 112 lobe? With your target RPM range, you'd want a wider LSA because you're obviously not going for torque with a 350.
Depending on the cam, using 1.5s would be a step backwards. Use a full-roller 7/16th stud 1.6 rocker.
Don't get so hung up on static compression. Since you likely don't know the valve events for that particularly bad choice of a cam, you don't even know your dynamic compression ratio, which is FAR more important than your static in determining the octane requirement for your motor. The good news is you understand that already.
I suggest you research what other people have done right since you are headed in the wrong direction.
and with "Since you likely don't know the valve events for that particularly bad choice of a cam" i do have a cam card somewhere i just dont know where i put it.
and I am going to have the block fully checked out and in the end will be going with what the machinist says when it comes to the bore of the block. So it may end up being a 355 if it needs to be.
now iirc eagle cast cranks arent worth their weight in dog s#it so that leaves scat. are scat cranks any good.
looking at this one
http://www.summitracing.com/parts/SCA-935050L/
and lt1s are internally balanced correct
