will this cam fit?
Cam will be going in a car with stock shortblock and ported stock heads that have NOT been milled.
thanks
I had a similar cam from Bret in my 396ci engine with AI heads. Here the specs: 236/248 .570/.541 with 1.5 RR 110° LSA and 110° ICL. Very hard to get it to run below 2000 rpm even with my 396, was a fantastic cam above 4500 rpm all the way to my shift point 6600 rpm. I was using a M6 ZF trani, an A4 would be much better in regards to bucking.
I got rid of this cam and switched to a solid roller, what a difference from idle up to 6900 where I shift at. Very happy with the SR and would never go back to hyd. roller.
thanks
I ran both in stock bottom end applications with great results...503 is a great DD cam,cc306 is about the biggest i would go with stock bottom end. never did i say the cams are similar.... I had a similar cam from Bret in my 396ci engine with AI heads. Here the specs: 236/248 .570/.541 with 1.5 RR 110° LSA and 110° ICL. Very hard to get it to run below 2000 rpm even with my 396, was a fantastic cam above 4500 rpm all the way to my shift point 6600 rpm. I was using a M6 ZF trani, an A4 would be much better in regards to bucking.
weren't you looking at a 236/242 on a 112? the cam originally posted looks like a stock shortblock, stock pcm "max effort" cam, and no... a 105.5 lsa is not too wide lol. If the guy wants to run a 4.11+ gear and a 4500+ stall it'll rip.
that is the cam that is going in my vette. I was asking this question for a friend...he is thinking of putting this in his 6speed formula.
