Vats system
Also I will need to get my pcm edited out for this correct?
Back of the car???
Yes, you will need programming or a bypass module for the 50hz signal to the PCM that allows fuel delivery.
http://shbox.com/1/pass_key.html
I believe there is a shock sensor in the RR.
VATS is in the BCM under the RH side of the dash. You'll have to read your owner's manual to see if the alarm interfaces directly with the VATS. I don't think so, but I don't have an alarm or BCM on my car.
Maybe you should state just what it is you are really trying to do.
What is that box so I can remove it completely!
Also sorry if I offended you or said something wrong
Complete VATS info is on my Tech Page.
The only aggravation is when people don't supply car info or details on what they are doing. Begging people for info gets pretty tedious. Most people notice that the better info they provide, the better responses they get.
Secondly is that the little shock sensor in the rt rear quarter what is that? If thats what it is?
