do rocker arm studs go in dry or with threadlocker?
Old Jul 13, 2010 | 01:36 PM
Nads06111's Avatar
Default do rocker arm studs go in dry or with threadlocker?
about to put them in and just want to make sure i do this right
Old Jul 13, 2010 | 02:00 PM
shbox's Avatar
I used some red threadlocker on mine.
Old Jul 13, 2010 | 02:06 PM
RamAir95TA's Avatar
Seems like some people use threadlocker, others use thread sealant. I used red threadlocker on mine as well.
Old Jul 13, 2010 | 02:39 PM
SS RRR's Avatar
Village Troll
Perhaps you should consider GREEN if you WANT your studs to LIVE.
Old Jul 13, 2010 | 03:58 PM
draggin97s10's Avatar
^^^LOL^^^^
i used teflon sealant on mine. but i do on alot of stuff.
Old Jul 13, 2010 | 08:58 PM
aboatguy's Avatar
Some of mine went all the way thru....so I used teflon thread sealant
Old Jul 13, 2010 | 10:26 PM
Nads06111's Avatar
I used some BLUE. Medium strength
Old Jul 13, 2010 | 10:33 PM
SoxXpupPeT's Avatar
I used teflon thread sealant. I wanted to make sure i wasnt going to have any vacuum leaks..
Old Jul 13, 2010 | 10:34 PM
shbox's Avatar
If the heads are ported (the OP does not specify) and any of the stud holes go through, then use some sealant.
