Intake Upgrade
Old Jul 14, 2010 | 12:22 PM
Shownomercy's Avatar
Man-Crush Warning
Default Intake Upgrade
When would it be beneficial to upgrade to a single plane etc over the stock breadbox?
Old Jul 14, 2010 | 12:57 PM
RamAir95TA's Avatar
At 6500 RPM+.
Old Jul 14, 2010 | 07:14 PM
joelster's Avatar
Originally Posted by RamAir95TA
At 7000RPM+.
LOL. You think a stock manifold will beat out a single plane setup at 6000rpm? You know better than to post stuff like that, irregardless of how many times people ask this question.
A single plane is much better than a stock manifold when your car is making much more power than stock AND you are spinning it a lot higher than stock.
Old Jul 15, 2010 | 01:16 PM
Man-Crush Warning
Shifts at 6500, traps a lowly 116, stock unported intake, and I am just curious whether it would be worth it to spend the money on a single plane versus porting the stocker.
Old Jul 15, 2010 | 01:19 PM
RamAir95TA's Avatar
Fixed.
Old Jul 15, 2010 | 07:15 PM
joelster's Avatar
What cam are you running? What cubes? Are you keeping the car for a while? Any upgrades in the future? What stall? The stock intake might make more torque than a single plane down low, but that would be moot if you are running a 4500+rpm converter.
Old Jul 15, 2010 | 09:09 PM
StealthFormula's Avatar
He's got a stock bottom end with a 224/230 .574"/.571" 107lsa cam and a Yank SS3600 stall. I have the same heads, cam etc. as he and on the dyno my power peaked at 6250rpm.
Matt I know your car all too well lol.
Old Jul 15, 2010 | 09:14 PM
Man-Crush Warning
heh.... cept your car runs as it should... and I have N20 that I need to throw in the mix still...
I would like to keep the N20 stuff, so a single plane would allow a carb style plate and much better distribution etc. Again, just curious.
Old Jul 15, 2010 | 09:18 PM
You never got the car dyno tuned did you? I picked up a 1 mph by tweaking the timing on the dyno. I then messed with my valves because some were inconsistent and went from a 116 trap to a 119. It could just be something your overlooking. Once you get it running up to par and add the spray that car is going to be nasty.
Old Jul 15, 2010 | 09:36 PM
Man-Crush Warning
It was tuned with a W/B and in car lab top etc...
I saw you sold off an intake.. you switching to a single plane?
Old Jul 15, 2010 | 09:56 PM
Nah still running a stock manifold. I contacted Josh (STOCKTA) to go above and beyond on a stock manifold. He did alot of custom epoxy work and really did a hell of a job. I'm starting to chase after the small things because I want to see how far I can push this car with the current setup. I haven't been back to the track for results with the current manifold but I think it will net me a small gain.
Old Jul 15, 2010 | 10:43 PM
hitmanws6's Avatar
OP with your setup I don't see you needing a single plane. A ported stock should be just fine.
