LT1 teardown question
try searching "crank hub removal" and you will see pics and ways people took theirs off. You sort of need to use a piece that bolts into the 3 holes for the balancer, then you use a bolt that is smaller than the threading of the crank to push against the crank and that way you can push against that bolt and pull the crank hub off.
Cheers -- Gary
