Lt1 heads on regular block?
Old Jul 21, 2010 | 01:28 AM
Akmack's Avatar
Default Lt1 heads on regular block?
Ok I have a block I built up out of a 94 suburban.. I have a weiand stealth intake and edlbrock 650 carb. I ended up with some lt1 heads ( casting number 10128347) so my question is can I use these heads with this set up? Can I just bolt everything on or is there major mods I have to make? If I can is this going to be a good set up? ( going on an airboat) thank you all for your time and expertise.
Old Jul 21, 2010 | 01:36 AM
robsquikz28's Avatar
Yes but you will need to have that intake modified to fit those heads and you will have to block the steampipes on the back of the heads for the reverse cooling. I would just buy some vortec heads and call it the day. Unless you want to keep the lt1 heads for your setup?
Old Jul 21, 2010 | 12:53 PM
RamAir95TA's Avatar
Definitely not worth the $$$ to convert those heads.
Old Jul 21, 2010 | 01:01 PM
suicidal racing's Avatar
nopee your would have to work over the water passages in the heads if im not mistaken also..i might be wrong im dead tired right now lol..
grab some vortecs and be done with it.
Old Jul 21, 2010 | 01:46 PM
96lt1m6's Avatar
This conversion has been done on thirdgen.org
by the time you are finished you could have had a pair of trick-flows
or just find Vete L98 heads
Old Jul 21, 2010 | 05:34 PM
aboatguy's Avatar
98lt1M6 hit it on the head.
By the time your done with the welding and machine work you could have bought better heads that fit without modification
