Weird Oil Pressure Issue
FTR I have the stock windage tray.
Speed Demon,
Whats the p/n for the Moroso windage tray you have?
http://www.summitracing.com/parts/MOR-23020/
I'm running the melling select 10554 too so it's not a pump issue.
My oil pressure now
http://s86.photobucket.com/albums/k1...=VIDEO0011.mp4
My oil pressure now
If the pickup tube hasn't fallen off, and if you're not cavitating, my only other thought would be a problem with the oil pump drive mechanism at the rear of the lifter valley (ie, the dummy distributor shaft).
The dummy distributor shafts are made of plastic, and have been known to break and/or bend -- thus the gear of the dummy distributor shaft (turning the oil pump) loses contact with the cam gear driving it. For this reason, I made a metal retainer plate to hold it in place. Again, just a thought -- might not be the problem here.
Might also consider hooking up a mechanical gauge and make sure it isn't just a buggy oil pressure sending unit/gauge. If it *always* happens with high RPM regardless of load, you could just rev the engine in neutral and watch the mechanical gauge. IIRC there should be at least one extra port on the driver's side of the engine block to tap into.
Check post #35. The OPs problem was the windage tray, not electrical.
