Identification time.. what is this?
Old Jul 24, 2010 | 04:57 PM
hyperzone's Avatar
Default Identification time.. what is this?
All kinds of surprises on the new car I'm fixing up. I never messed with fuel pump stuff. I noticed after pulling the carpet that somebody has cut the hole for fuel pump access. I took a peek and here's what I see :
What is supposed to be hooked to the one I circled? And while we're at it, which lines are what? Thanks.
Old Jul 24, 2010 | 05:06 PM
Adam1203's Avatar
im fairly sure that one runs to the canister by the filler neck i think its the charcoal canister . the only reason i know is i forgot to connect mine and i got to pull the tank again when im done putting the motor in.
Old Jul 24, 2010 | 05:16 PM
ThreeHonks's Avatar
If you have EVAP removed that will be like that
Old Jul 24, 2010 | 05:22 PM
hyperzone's Avatar
Well, the car is mine but still new to me. Had a 96 SS prior to this and when I got that it was completely stock. The more and more I explore this car, the more I find out how much it has already been tinkered with. Up to this point there's been alot of screwy things I've fixed and just wanted to make sure this wont ben an issue.
I'm not worried about smelling gas fumes but, is there a real bad hazard leaving that line just sitting there not hooked to anything? Will it being open like that affect the operation of the car in anyway other than emissions stuff? (engine doesn't have evap, egr, air, cats anyway)
Old Jul 24, 2010 | 05:35 PM
Adam1203's Avatar
if it was me Id cap it. you can get caps for vacuum lines at advanced auto that will fit over that. if you can get one let me know i got a bunch of assorted sizes laying around ill mail one to ya.
Old Jul 24, 2010 | 05:37 PM
hyperzone's Avatar
Thanks guys.. I do have some vacuum caps that should fit but, doesn't the system need to be vented?
Old Jul 24, 2010 | 05:44 PM
Adam1203's Avatar
one of those is a vent line that runs down to a white vent on the driver side right before the rear axle. its mounted to the same mount as where the brake line connects to the body.
the other two lines run to the engine one is the sending line and the other is a return.
Old Jul 24, 2010 | 06:55 PM
RamAir95TA's Avatar
For further clarification:
The two lines with the white quick-release fittings are the feed and return fuel lines.
One of the hard rubber lines goes to the white fuel tank vent valve, and the other goes to the EVAP canister in the driver side quarter panel.
Old Jul 25, 2010 | 12:02 AM
the_merv's Avatar
That's the Tank Vent, the farthest one on the right is the EVAP.
That's how it was on my 95z.
