Left-overs
Old Jul 24, 2010 | 07:43 PM
ebeard's Avatar
Default Left-overs
Engine is almost hooked up after the rebuild and cam swap. Anybody recognize this stuff?
Old Jul 24, 2010 | 07:47 PM
LT1_Fireman's Avatar
the bottom left is to hold the oil cooler lines to the side of the block...
Old Jul 24, 2010 | 09:25 PM
ebeard's Avatar
also on the two wires that come from the battery to the starter where does the shorter one go?
Old Jul 24, 2010 | 10:02 PM
litch2004's Avatar
The bottom two are the oil cooler brackets and the upper two are the tabs for the factory plastic spark plug wire looms.
Old Jul 24, 2010 | 10:10 PM
litch2004's Avatar
And only the big wire from the battery should go to the starter. The only small starter wire (purple IIRC) comes from the wiring harness which is connected to your VATS relay in the cab. The other smaller wire from the positive post goes to the small post on the back of your alt.
Old Jul 25, 2010 | 09:19 AM
ebeard's Avatar
Got it. Thanks a lot!
Old Jul 26, 2010 | 07:12 AM
DAVE00's Avatar
Ummm - No. The top two are for mounting accessories to the trottle body like the TB cable cover.
Old Jul 26, 2010 | 05:00 PM
ebeard's Avatar
Kind of unrelated, I got rid of the hose that runs from the back of the pass. valve cover. I have seen breathers used to cap the hole. but can I just use a solid cap?
Old Jul 26, 2010 | 07:48 PM
Speed Density's Avatar
hashtagBMW
Bottom right actually looks like a piece that "should" be tacked on to the coolant crossover lines.
Old Jul 26, 2010 | 08:03 PM
JB_97ws6TA's Avatar
the top two look like the brackets that hold the AIR pump solenoid on the left hand stud of the ignition coil. I think the wire that he is speaking of is the ground that goes on the passenger side motormount against the block, if it is a thin gauge purple wire it goes to the started if it is a heavy gauge ground than it goes to the mount
Old Jul 26, 2010 | 09:49 PM
97lt1camaro's Avatar
The top left looks like the bracket on the throttle body to me.
Old Jul 27, 2010 | 01:24 AM
happysem's Avatar
+1
I think both of them are for that.
What is it actually for though?
When I switched to my new TB I just left it off because it was literally attached to nothing.
EDIT: read a previous post. I remember what they're for now.
Old Jul 27, 2010 | 03:51 PM
ebeard's Avatar
Yeah I figured out the starter ground last night. The bottom right i saw in another thread with the rear AC bracket.
