383 Stroker kits
Old Jul 28, 2010 | 03:28 AM
J-13gtp's Avatar
Default 383 Stroker kits
Has anyone used this kits on ebay?
Couple of examples
http://cgi.ebay.com/ebaymotors/Sbc-E...item2eaed39ed4
http://cgi.ebay.com/ebaymotors/LT1-3...item35a25a4c71
Any comments? And just how well would theses kits handle NX?
Old Jul 28, 2010 | 03:31 AM
brucer's Avatar
not a very good kit...
stay away from cast cranks... your stock crank is better than a cast crank.
Old Jul 28, 2010 | 03:35 AM
J-13gtp's Avatar
Should've figured
If something is cheap there must be a reason for it.
Old Jul 28, 2010 | 04:12 AM
nik1703's Avatar
you probably dont want that eagle crank.
ive read 10000 threads titled "my eagle crank broke!"
Old Jul 28, 2010 | 09:52 AM
DAVE00's Avatar
Eagle Cast stay away from but Eagle Forged is very good quality. I've had an Eagle setup (forged of course) in my 383 for over 12 years and ZERO issues.
Old Jul 28, 2010 | 10:02 AM
brucer's Avatar
yep ive read 2 threads on broken eagle cast cranks,on 2 different forums over the last few months..
your stock crank is a good, nodular iron crank...if your looking at a budget build use it.. get the assembly balanced, and your good to 6500rpm..
alot are running the stock crank, and using a set of h-beam rods, and forged pistons.. i'm going with reground stock crank, 94stock rods-resized with arp rodbolts, and speedpro flattop pistons..
