I have a 93 z28 130k A4. Last year i went 13.61 @100 with a 1.98 60' on et streets and stock converter.It has a shift kit,3.23 gear,hooker headers and exhaust,no cat,air foil,1.6 rr's but all other internals are stock to my knowlegde,moroso CAI. So this year i added a walbro 255 because the stock pump went bad. I also added a yank SS3600 and a PCMforless tune. Went back to the track and ran a 13.43@99 with a 1.92 60' on the same tires as last time. I know i should be in the 12's with this set up. My car runs rough at an idle, the idle, volts and oil pressure go up and down at the same time. Not real bad but enough to bug me and fell rough. I have replaced the plugs,wires,icm,egr,coil,map sensor,tps sensor and as stated above the fuel pump. The car also has a spot around 5k where it think for a second and then from 5k to 6k it pulls hard again, when it shifts into third it falls on its face and feels slower than first and second. It is not the tune either because i pulled that and slowed down three tenths. Only thing i can think of is possibly the opti is going bad but it tested fine when my friend scanned the computer for me. Any ideas are appreciated and thanks for everyone's time.
