guide boss clearance?
Old Aug 6, 2010 | 06:12 PM
LSWHO's Avatar
Default guide boss clearance?
I have a 230/230 601 (1.6s) lift cam 107lsa
Can somebody explain the guide boss clearance for me?
Old Aug 6, 2010 | 06:15 PM
ThreeHonks's Avatar
not even close (I still would check anyway) but with my past expereince that wouldnt even be close
Old Aug 6, 2010 | 06:21 PM
96lt1m6's Avatar
PTV should be good to go.....HOWEVER,i would be concerned with retainer to to guide boss contact. there are locks that will give you added clearence +.050 for a few extra bucks.
Old Aug 6, 2010 | 06:27 PM
Wicked94Z's Avatar
Originally Posted by LSWHO
No real porting and bigger valves, would I be in trouble?
yes. bad idea.
Old Aug 6, 2010 | 07:07 PM
LSWHO's Avatar
So... leave the valves alone then. Splain the guide boss part to me. I'm dumb. I have the 8501-BSBC spring kit. Will that change anything?
Old Aug 6, 2010 | 11:49 PM
LSWHO's Avatar
Anybody?
Old Aug 7, 2010 | 11:43 AM
JAKEJR's Avatar
Not sure what you're asking.
Are we talking the clearance between the valve stem and the ID of the valve guide?
Are we talking the clearance between the underside of the valve spring retainer and the valve guide boss with the valve fully open?
Are we talking about the clearance between the ID of the valve spring and the valve guide boss? Valve stem seal to valve spring?
Help us out here.
Jake
Old Aug 7, 2010 | 01:46 PM
LSWHO's Avatar
I honestly have no idea. Whatever 96lt1m6 was talking about. I was asking about possible ptv clearance with my 107 lsa cam and he said he'd be more worried about boss clearance with 601 lift.
 Michael S. Palmer
Old Aug 7, 2010 | 02:35 PM
96lt1m6's Avatar
The area under the retainer comes close to the top of valve guide boss at .600+ lift...
If you do not get the heads machined you should get the retainer locks/keepers that will give you .050 extra clearence..... Not a big deal to install
Old Aug 7, 2010 | 04:04 PM
LSWHO's Avatar
When you say that is that for a specific installed height? Any clue as to what height is needed for the clearance?
Old Aug 7, 2010 | 04:14 PM
96lt1m6's Avatar
What installed height are your springs supposed to be at.?
Old Aug 7, 2010 | 04:25 PM
1SWT95Z's Avatar
i think 96lt means retainer to seal clearence when at max lift. if you have stock length valves, a .600 lift cam would be close. But I think you would still be in the .100 of clearence range. even though it seems tight, clearence is clearence, not interference.
Old Aug 7, 2010 | 04:26 PM
LSWHO's Avatar
The springs I have are 1.80" installed height.
Old Aug 7, 2010 | 11:30 PM
LSWHO's Avatar
Thanks for the info so far guys, I'm trying to get my valvetrain purchased and ready for the swap.
So as far as the 1.80 installed height.. is that enough?
Old Aug 8, 2010 | 04:08 AM
96lt1m6's Avatar
you should be ok with 1.80 but i like to be sure. you can also give Lloyd Elliot a call since he does these heads all day...just lookin out for ya
Old Aug 8, 2010 | 12:30 PM
LSWHO's Avatar
I know man. I DEFINITELY appreciate it. There's so many things to check I had no idea. I'm glad I'm learning though. I love this type of info.
Old Aug 8, 2010 | 01:16 PM
96lt1m6's Avatar
No problem bro, my machinist showed me quite a bit and i was really suprised to see how close we get to disaster when we stick large cams in motors and or run at high RPM.
