Question on injectors
Old Aug 16, 2010 | 03:14 PM
96blackz28's Avatar
Default Question on injectors
Im gathering the rest of the parts to finish my build. My question is, do LS1 injectors fit LT1? My friend has a set of 34lb injectors from an LS1 motor and I want to make sure it will work.
Old Aug 16, 2010 | 03:28 PM
RamAir95TA's Avatar
They will work but they are rated at a higher psi, so those 34# injectors are closer to 25# injectors when ran at 43.5psi.
Old Aug 16, 2010 | 03:46 PM
96blackz28's Avatar
Ah alright, so not worth it then. Thank you
