injector offset what the heck!!!
Does anyone know why the injector offset doesn't seem to work probably on my 94 lt1 ? I tuned the new Bosch 3 30lb injectors using the original multitek offsets with TunerCat software. these are similar to the ford type M-9593-AA302 . for reference these injectors have a .666 ms at 13 volts compared to the multitek at .305 ms . When I pluged in the bosch offset values the blms will log extremely rich at the 3000 and lower RPMs through most all the Map values.So I have been trying to understand why this would happen when there ample amount of injector timing degree opportunity in the lower rpms. Does anyone know how the ECU coding determines when to actuate the injectors ? I have a hot cam with more duration then the standard cam so mechanical there should be plenty of cam degree timing to accommodate .361 ms of additional timing.
As anyone had the same issue?
Make sure that is not the case...
Or better yet leave the offsets stock like 99% of everyone else out there.
If you had a big set of injectors you may need to tweak the offsets to help with driveability but I really dont see the need with 30lbs.
JMO
VDC Usec
12.4 427
12.8 336
13.2 305
LDC
