02 wire hack and rant....
i'm currently running with the o2's unplugged and issue is nonexistent,...but being that i'm OCD bout my car it bugs the crap outta me.. Also is the o2 wire really that damn sensitive? only way i could make it any better connected is to solder it straight to the damn o2's bare wire...
i cut and spliced already so...
say i buy and install an ext. i still have to splice the plug back on that was cut off, so i dont see how buying those ext's would make any difference ....seriously the wiring i installed cannot be that different from a bought ext. and its connections....... i even used liquid electrical tape to seal the double crimped connections so no moister or dirt is even a factor...thus my theory of the non heated o2 and Lt's being the culprit....*plus aside from MANFRED's post you guys have 4-wire heated o2's...
this may be what i need to convert to....i hate just f'ing guessing and throwing parts at ****!
Check out Fastbird's page. He's a member on here and on LTXTech. Sounds exactly like your problem. Splicing wiring (as long as it's done right and you've used the right type of wire) wouldn't cause this issue. If you read the description on Fastbird's site, it explains your problem to the T.
Edit: You might want to PM him (his name is Fastbird93 on this page, and just Fastbird on LTXTech) to let him know you're interested in his harness and/or have paid for one through his site. He's doing a pretty extensive build right now, and has a lot of other stuff on his mind. Letting him know by PM might be a good idea. As far as I know, he makes all the products he sells himself.
