security light flash Help
94 Camaro Z28
list of mods
96 383 stroker motor
4 bolt splay
Lunati crank
Oliver I beam rods
je inverted dish pistons
comp cam 290 hr-12
comp cam promag roller rockers 1.6
AFR 210 heads
2500 stall
BBK 58mm throttle body
stock intake port matched
pacesetter long tube headers
off road Y-pipe
flow masters
Security light can go on if its wrong key resister value on the chip. it can also go on if the ignition cylinder orange/white wire is broke or open. But if the security light flashes your car should not start unless it has been bypassed.
i just thought it was funny youre having security light issues and you listed off your mods.
Maybe whatever is in the ignition cylinder that reads the chip is going out?
Make sure the key your using has the same resister value as the original key. Use this website for reference on resister value.
http://shbox.com/1/4th_gen_tech2.html#pass_key
