school me on Opti's please..
I have 42psi on the fuel pressure gauge, but no spark at all on multiple plug wires. I started with the easy stuff. I had autozone run 5 back-to-back tests on my ICM, its good. Coil tested good (Accel unit).Using my multi-meter, I placed the red probe on the coil terminal, and the black lead on both wiring pins and got a reading of 9.41 on both terminals. Ignition fuses are good, and I have power on both sides of the fuses. My SES light is on, but I dont have access to a code scanner that will work on my 95 since its an OBD1 car with an OBD2 ALDL port.
2. Yes, waterpump was replaced about a month before i bought it. PO also said this is when it started acting up. I figured it was in need of a new opti, I just wanted to test it for myself and learn something new for future use..
I'll be ordering a chandler opti later tonight...
